Slab on Grade Loading
Do I need to consider slab on grade loads (Dead and Live) on adjacent grade beams or foundation walls?
Is there a difference if I key and dowel the slab into the grade beam?
I have heard mixed advice. The most common approach I have heard is to take 1 meter of tributary width of the slab on grade.
RE: Slab on Grade Loading
BA
If you go through the numbers, you'll likely find that BAretired's approach is fine, but would be good to satisfy your curiosity.
