Minimum bolt size to fit existing hole?
We’re designing a steel structure to support a piece of round mechanical equipment with 4 mounting lugs located 90 degrees apart. The mounting lugs of the equipment each have a slotted bolt hole of 1.25” by 2.5”. What is the minimum size bolt that can fit this 1.25” hole (slot)? Must the bolt be 1/16” less than the hole size (1-3/16” in this case)? The bolt won’t experience any tension. I looked through AISC 325 and didn’t find the answer. Unlike this situation, typically the hole size is selected to match the bolt size.
RE: Minimum bolt size to fit existing hole?
If the mounting bolts are purely for axial loads then I would propose detailing the mounting bolts using criteria similar to anchor rods at base plates. A 3/4" diameter is the minimum size that can be used in a 1.25" wide slotted hole. A 5/16" minimum plate washer with a standard hole(2" min in short direction, length sufficient to completely cover slot) would be required also.
If the bolts are intended to resist shear loads then you would either need to provide a bolt 1/16" less than the hole size or provide slip critical bolts for the connection.
Bridgebuster - nice name! Where in the RCSC is can I find the minimum bolt size for the given hole?
Depending on the dimensions and tolerances of the lugs, and your structure, 1/16" undersized bolts might fit fine, or just one bolt will fit, or it will be impossible to install any bolts at all.
Your lugs //may// be rotated 90 degrees out of plane to the following examples, but I ??think?? the concerns are roughly the same.
https://encrypted-tbn0.gstatic.com/images?q=tbn:AN...
http://www.2-speed.com/2010/10/dual-bolt-pattern-w...
http://img689.imageshack.us/img689/8344/unilug.jpg\
http://www.roadsters.com/E-T_III_500x492.jpg
