Drawing translation
Drawing translation
I'm working on a German to English engineering documentation translation project and have come across a welding note I'm not sure how to translate. The note reads "Schweißnaht mit R2 bearbeiten" which seems to translate to something like "weld with R2 process". I'm not sure what R2 process is. It is attached to a square groove weld symbol. Any ideas?
RE: Drawing translation
mit R2 bearbeiten = machined to 2 mm radius (I assume mm for units)
