AutoCAD 2015 SP2 Std ribbon, Home tab, Block, Insert - Thumbnails no longer appear
I just noticed this morning that when I attempt to insert a block using the standard ribbon, i.e. from the Home tab, click on Block, then click on Insert, the drop-down shows the block names, but no thumbnails appear.
I am running 2015 SP2 under Win 7 Pro x64. The only system change I might suspect as a contributing factor is a 24 item Windows Update that was done last night.
Anyone here experience the same issue?
Ralph
Structures Consulting
Northeast USA
RE: AutoCAD 2015 SP2 Std ribbon, Home tab, Block, Insert - Thumbnails no longer appear
The puzzling thing is that it only occurs with one DWG file. That file happened to be open in AutoCAD when Win 7 decided to apply the updates. I have not yet tried to insert that DWG file into my template file which, I suspect, may resolve this issue.
Ralph
Northeast USA
