how to drilling a long hole in a square bar
I need help in choosing the correct machining process to drill the long hole shown in the attached drawing
Material: steel SAE 1045
All dimension are in mm
any comments?
Thanks!
any comments?
Thanks!
RE: how to drilling a long hole in a square bar
First pass, end mill the slot, then go after it with the custom cutter to get the round shape. Treat it like you're milling t-slots into a table, but with a round profile.
Alternatively, if you absolutely have to use a drill, or can't get a custom cutter... I'd start with a larger block that encompasses the hole size completely, get a decent gun drill, drill the hole, then mill the block to size, opening the hole up.
You don't specify tolerances, quantities, etc, so it's hard to give one answer.
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
Can't do it in one pass though.
Bore Tolerance: +/- 0,5
Mike Halloran
Pembroke Pines, FL, USA
I found a machining shop that was willing to give it a try. They are going to try to do the hole in a lathe
If this does not work I may be doing a redesign on the guide. I need something that is easy to make
I will comeback when the test has been done
I have changed the design of the guide. I bought a steel tube and made 3 supports (they are needed to bolt the guide to the machine) and the next step is to ground mill the face that is laying on the table (see picture attached)
So far looking good
Will be coming back with the finished guide report
Ground mill?
Slab mill
Herman
http://mymachineinfo.com
