Kinematic Distance and Band Analysis output
Hi - I have a series of compiled simulations with Distance applications set up all within one Catia product. I would like to be able to extract the distance outputs to a file but I am unable to do so. It appears that once you have created a Simulation you cannot add Distance applications and get a read-out using the Edit Sensors function as Distance Applications added after initial creation do not show in the pick list. (The only ones that show are those created when the Simulation is created).
There are about 100 steps in each Simulation and I don't want to re-create them if at all possible as I really need to add more Distance applications as the job progresses.
Is there a way of extracting what I need?
Catia V5 - Service Pack 9
