Maximum allowable stress for A105 II
We are having troubles in Venezuela where I work, and I can´t find some data. I need the maximum allowable stress (S, the value in thickness calculation in ASME section VIII, div. I) for A105 Grade 2. I know is a plate but th vessel has been made laminated.
RE: Maximum allowable stress for A105 II
A-105 2 doesn't exist.
Allowable stress is 20.0 ksi at 200°F.
Well, of course ASTM A-105 is a common forging material and the allowable stresses are given in the Codes.
ASTM A-105, Gr. 2 is used in forged socket weld fittings, some forged valve bodies, in-line traps and filters, etc. I suspect that a focused search of the internet will yield the information that you require.
Regards, John.
ASTM A105 - Grade II is a forging, but this grade does not appear in current standards - it is simply listed as ASTM A105 in current standards. The Grade II designation was dropped sometime after 1972. I can't tell you the exact year, since I do not have access to all of the old ASTM standards. You should use allowable stresses in the Code year applicable to the design.
