Creating custom attributes in Operation Part Navigator
Greetints!
I would like to know, is it possible to create/add custom attributes in Operation Navigator? For example, I would like to see the cutting parameters - part stock, cut depth, stepover and so on.
I would use it for creating shop documents, because I could easily convert it to spreadsheets.
Thanks in advance! :)
RE: Creating custom attributes in Operation Part Navigator
Go to Configure and
Add the required attribute name and say create.
Mathi K
I am not sure how old your version of NX is, but I just looked at NX 10 and as you can see in the attached picture there are many more columns that what you see.
The parameters you are looking for are available during postprocessing and shop docs.
For stepover, you will need to write some code if you want to interrogate all the possibilities, such as max, exact, %Tool, number of passes, scallop height, variable, maultiple, ...
Mark Rief
NX CAM Customer Success
Siemens PLM Software
