Simulation of the performance of antennas
I would like to know if it's possible to have information about the E object(the wave)reflected from the object after it has been illuminated with another antenna. I would like to simulate a specific configuration but I need to have Eobject as shown in the figure.
So is it possible? And is there software which enables me to simulate it directly after specifying E ref and the characteristics of the antennas? or I should find a way by modelling it ?
I am new in this domain and I would appreciate any help
RE: Simulation of the performance of antennas
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
(Geometrical Theory of Diffraction / Uniform Theory of Diffraction)
But can anyone tell me if FEKO software can do it?
It looks like it should be able to handle it.
I can imagine that the software learning curve might be the most significant issue to plan for.
If there's any other ideas , I would be grateful :)
If you search using the terms cylinder canonical utd then I'm sure you'll find probably too much info.
