Etabs 13 base shear calculation check according to UBC97
Hi guys,
I would like to share with you this incidence,
I was running an Etabs 13 model and checking the calculated base shear (according to UBC97),
This is what I have got (image attached),
The used period to calculate the base shear in X direction was not taken as per the “Modal direction factor table” which indicate that the period in X direction is 0.469s with a 76.3% participating ratio ..
Am I missing something here ?
RE: Etabs 13 base shear calculation check according to UBC97
