problem Tools -> Record NX10 flyouts are not recorded
I have seen the NX10 function Tools-> Record work OK with a standard install.
But I work on two different PC's both installed with a version of Camtasia.
When I try to record some constraining (eg Collinear) the flyout menu is not recorded.
When you wait long enough the help text is displayed and this is recorded properly.
See attachment.
My question can anyone verify this problem with NX10 and Camtasia version installed.
Olaf
See attachment.
Olaf
RE: problem Tools -> Record NX10 flyouts are not recorded
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the response.
I did a new clean install even (manually) registry settings concerning NX 10.0.
But I got still no fly outs.
@ John, Camtasia has the same problem see attachment.
Olaf
Try lower the hardware acceleration and then try capture again.
Are you running a certified graphics adapter / Driver ?
Tomas
