Centrifuagal compressor
in centrifugal compressor what is the equation used to know the outlet optimum temperature with respect to inlet and outlet pressure , or compression ratio , and inlet temperature ... in the isentropic compression phase
RE: Centrifuagal compressor
your question is not clear, have you access to GPSA Handbook ?
It includes all formulations and examples,
depending from application there are different methods (Ideal, Schultz, Huntington etc.) for some basic examples see
"http://www.cheresources.com/invision/topic/16367-w..."
