Hydraulic properties of clayey soil
Hi guys!
Currently I am involved in a benchmark project for the ICOLD (International Committee for Large Dam) for risk assessment of an embankment dam. One of the failure modes is of course sliding instability of the downstream slope. For the project a very simple approach is proposed for the pore-water pressure calculation - from water tables for different pool levels. However I wish to perform some transient seepage analysis to get an insight on how conservative is this approach for the particular case. The organizers don't have hydraulic parameters of the soil, only some strenght properties - friction angle with mean value of 25 degrees and cohesion mean value of 10 kPa (these are effective stress parameters).
My question do you know published relations (if any) between strength properties and hydraulic properties - I need rough estimations of hydraulic conductivity and water content (vs matric suction). Also what value for the hydraulic conductivity anisotropy Ky/Kx is reasonable in your opinion?
Thank you!
Thank you!
RE: Hydraulic properties of clayey soil
f-d
ípapß gordo ainÆt no madre flaca!
