Amine Unite Material Selection
Experts,
We have to select the materials of an Amine Unit removing CO2 (Up to 80% removal) from the following gas:
Feed Gas composition:
H2O : 0.18 mol%
CO2 : 16.51 mol%
CO : 2.41 mol%
N2 : 0.30 mol%
H2 : 74.79 mol%
C1 : 5.81 mol%
Total: 100 mol%
Amine Used: Monoethanolamine
What the major damage problems that shall be taken into consideration in this unit regarding the gas composition?
Thank you in advance.
RE: Amine Unite Material Selection
Can you first provide what is your findings in this? If anything I feel additional, I will add.
Start with API RP 571 and look up amine corrosion and amine stress corrosion cracking, then take it from there.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
