UNABLE TO OPEN INPUT FILE ON UNIT 5
Hello community, I have the below mentioned problem while running 6.14 version of Abaqus:
UNABLE TO OPEN INPUT FILE ON UNIT 5. FILENAME C:\Users\249A~1\AppData\Local\Temp\ÂáããÝëçò_Job-1_10488\Job-1_f.inp.
The results will not show no matter what I do.
RE: UNABLE TO OPEN INPUT FILE ON UNIT 5
Don't use any special signs in the path or the file name.
Thank you for your answer.
No special characters were used in the working directory or the file name.
Just a wild guess, is it possible that the full path name is too long (your seem to running it on Windows)?
And wow about read/write access rights of the process into that file/folder?
