Determine if the motor is WYE or DELTA
The motor that has no nameplate and has only 3 wires out.
How could we know the connection of a motor if it is star or delta?
RE: Determine if the motor is WYE or DELTA
In classical text-book electricity, there is no possibility to do measurements to see if a circuit is wye or delta connected.
In an induction motor, however, there is a possibility to see the difference: Record the stator voltage when the rotor is rotated and see if you have very low triplen harmonics (use FFT to see frequency contents). Triplens are very low if delta connected since 3x120=360, so they "compensate" each other.
Your problem is that you cannot reconnect and measure wye and delta. So, it doesn't work for you.
But it doesn't matter. So just relax and leave it.
Gunnar Englund
www.gke.org
Delta: One winding group will be magnetized strongly and the other two groups will be at half strength.
Wye: Two winding groups will be strongly magnetized and one group will be either not magnetized or weakly magnetized.
Bill
"Why not the best?"
Jimmy Carter
When does one need to know?
(Except for evident cases and when all six wires are available)
Gunnar Englund
www.gke.org
Gunnar said it best.
"When does one need to know?"
And to be fair, I seem to remember you saying something similar a few years back, David.
Bill
"Why not the best?"
Jimmy Carter
Once there's at least 6 leads the whole ball game changes. Nine leads seems to point to one internal wye. Six or twelve leads can be either, or something else altogether. With 6, 9, or 12 it's important to connect it correctly for the applied voltage. But 3 makes it so simple, either it works at the supply voltage or not. No worries about a whole variety of specialized motors that may show up with more than 3 leads.
The OP must have life far too easy and wants to find ways of complicating it.
Low voltage wye:- one group of three leads and three groups of two leads.
Low voltage delta:- three groups of three leads.
And some 6 lead motors are single voltage, part winding start.
And then there is 10 lead machines. Used for wye connected generators with what would be the buried wye connection in a motor brought out for the neutral.
10 lead generators are a challenge to reconnect for single phase. Niether the zig-zag connection nor the double delta connection works.
For the lower voltage connection, the Bar-Diamond or Collin connection will work for the lower voltage single phase.
The common voltage of a reconnected genset is 120/240, so the Collin connection works fine.
Bill
"Why not the best?"
Jimmy Carter
For example, in case of single phase use of three phase motor, the capacitor value (consequently HP) depends significantly on whether the connection is delta or wye.
Bill
"Why not the best?"
Jimmy Carter
