Python command to load temperature dependent material properties
Hello all,
I want to input my material properties through my python script from a tabulated file (Located in C:/Temp/Steel.txt). The command needs a tweak after the table portion of the following command:
mdb.models[Modelname].materials[Steel].Elastic(table=((200000.0, 0.3, 20), ))
however I would need your help on how to solve my issue.
Thank you very much!
RE: Python command to load temperature dependent material properties
You have to fill something like this automatically:
mdb.models[Modelname].materials[Steel].Elastic(table=((200000.0, 0.3, 20), (180000, 0.28, 100)))
So you do it by replacing it with a variable:
mdb.models[Modelname].materials[Steel].Elastic(table=(x))
And now you have to create x to fit in there. x can be a list or a tuple. The content is number of tuples. So x looks like this:
x=[(E1,PR1,T1),(E2,PR2,T2)]
To get that you can create a list [E1,PR1,T1] and convert that afterward to a tuple. Now you can add that tuple to the list x.
Thanks! Made it work this way... Took some time until I understand how tuples work....
