pipe & fittings
pipe & fittings
what will be the length of 1/2" NPT hole in a test blind,ASTM A105/36"/ API-600# ?. or from which standards i can refer the data?.
RE: pipe & fittings
You need to provide more information on the blind plate for hydrostatic testing. Is this a through-hole (through thickness) or a partially drilled hole in a blind plate? You may need to use a dished head for testing.
RE: pipe & fittings
