FRP Anchors into Concrete
I have an application where I've got some FRP Angle pieces I need to attach to uncracked concrete. I had thought to simply use expansion anchors, but wondered if there might be someone who makes fiberglass (FRP) versions of those, or if I could simply epoxy them into place similar to HILTI epoxy anchor system.
It would seem logical to use FRP rather than metal anchors. There's not anticipated to have a significant amount of force on the angles. This is just to hold them in place.
RE: FRP Anchors into Concrete
Illbay:
I'd stick with stainless fasteners. You might experience degradation of the FRP from the alkalinity of the concrete.
DB
