Slab - twisting moments
Dear,
I need to model 3 type of 2-axis slab models in Robot Structural Analysis 2014: drillfrei, drillweich and drillsteif (German terms). My German is not so good so I presume it has something to do with twisting moments of the slabs so it will be, i think: without twisting moments (drillfrei), with twisting moments but with the support uplift (drillweich), with twisting moments without support uplift (drillsteif). I have found some examples modeled in other software:
http://www.isa.fh-trier.de/home/Projekte/FEM_nicht...
In folder Beispiel1--Berechnung mit RFEM (drillweich) and (drillsteif).
1. Has anyone met before with terms drillfrei, drillweich and drillsteif and am I correct connecting these with twisting moments?
2. If yes, is my assumption correct:
- drillfrei - I should model orthotropic slab leaned on 4 sides on pinned line supports, but with torsional stiffness = 0,00
- drillweich - model simple slab leaned on 4 sides on pinned line supports, but with allowed uplift of the support UZ+
- drillsteif - model simple slab leaned on 4 sides on pinned line supports
3. Am I making something wrong here about these slabs?
Thanks for Your time!
RE: Slab - twisting moments
Can anyone answer or at least delete the post (because it is useless then)?
Can't you contact their tech support group? Then you could update the rest of us on the subject.
Note:
My first thought is that these terms might refer to the "drilling degree of freedom" for the plate. But, that is based on Google translate interpreting the terms as Drill - Soft (weich), drill - free (frie) and drill - stiff (steif).
I asked RSA support but still no answer, but it is not important which software I use. I used Google translate too but I am not sure are models correct, like I described in first post. Thank you for trying to help JoshPlum!
The topic is way over my head so for once I've chosen to keep my mouth shut and not respond to something I don't understand. Doh! Whoops, too late, there I went and did it again!
It sounds like a rather complex problem but, that said, if you can post a sketch of what you're trying to investigate then probably some people on this site might be able to offer insight borne of years of experience.
I am trying to model these 3 slabs and compare the results as I wrote in first post.
Examples and sketches are in the link as you can see in the first post.
People experience is the reason I asked on this forum.
Ah, I missed the link. Sorry about that.
