View To Model Error
View To Model Error
Has anyone experienced problems running View To Model on area filled/hatched artwork? We are experiencing issues on NX7.5 NX8.5 and NX9 where the fill either disappears randomly or randomly fills in the object completely after View To Model is ran. This is a process we run routinely in NX5 with no issues, see attachment for example.
RE: View To Model Error
In that case it turned out to be that 'Extracted Edges' was turned off for the view. Not sure it's the solution you're after but it's worth a try.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
