Change hot water heater connections to match water supply?
I am specifying a Bradford White D-75T-125. The water connections are 1-1/2", but our building supply is only 1-1/4".
What is the best (safest) way to reduce these connections? Just a simple reducing/drop adapter, or will I need a special pressure reducer?
Thanks!
Nathon
Thanks!
Nathon
RE: Change hot water heater connections to match water supply?
Why are you specifying equipment with a larger water pipe size than you have available pipe? Is your heater oversized?
The civil plans were approved for 1-1/4" supply, so we don't want to change the size and resubmit.
Do you know if I can and how to reduce the connections?
Thank you
