Switch Gear: Heat Loads
Although there is a rule of thumb that all power to electrical/electronic devices is assumed to be lost as heat, I am calculating greatly elevated theoretical temperatures vs. empirical data. I believe the cause of this disparity is that the assumption is overly conservative for switch gear, and the like. For switch gear, not all power is lost as heat or else there would be no power to deliver downstream! Therefore, wouldn't it be smarter to account for dissipated heat by applying the efficiency rating (or, rather the inefficiencies) of the equipment? Surely, others have been down this road, as well. Your thoughts?
RE: Switch Gear: Heat Loads
Unless of course the E-engineer greatly undersizes the wire and someone puts bolts into the fuse holders:)
