NX 8.5 thread callout not showing in drafting view
I have made a drawing (master-model) of a part that has a threaded hole in it. I would like this threaded hole callout to appear on the drafting view. I have been using the insert>dimension>feature parameters function, then selected the features in the list, the drafting view (a pattern) I would like the information to appear in, hit ok and then nothing happens. In top of the screen the message "solid is invisible in view" appears shortly. What am I doing wrong in this already so complicated workflow for something that should be so easy?
