Oil/Water Separators
I have a project with a maintenance garage floor drains discharging directly to the sanitary sewer. According to the Town sewer ordinance and plumbing code, an oil/water separator is required prior to discharging to the sewer. Did some research, called reps, etc. Found a wide variety of oil/water separators and oil/sand separators. Seems like I just need a oil/sand separator (basically a tank with baffles) for gravity discharge to sanitary sewer. Does anyone see any cons to using a simple concrete tank (one piece, say 1,000 gal), w/ booted pipe connections, risers for access during cleaning, baffles, and outlet pipe tee'd to the bottom of the tank? Seems like the most cost effective, simple solution for a maintenance garage with minimal flow.
RE: Oil/Water Separators
http://www.oldcastleprecast.com/plants/ncproductsg...
I have specified Zurn units in the past with good results.
