Re-pad on Branch B31.3
3
Hello all,
How do I determine if repad is required or not on 45 deg branch, the branch is 12" and run pipe is 28". It will be a stub-in.
TIA
FC
RE: Re-pad on Branch B31.3
Perform the calculation as per B31.3 304.3. If you dont satisfy the area replacement in 304.3.3, you need a pad.
Or an ~"integrally reinforced fitting"
Thank you sir!
Note that 45 degree reinforcing pads is tricky to make and hard to install. Make sure that bevel and weld details are correct for the profiles you'll need.
Bellows Manufacturing and Research, Inc.
https://bellowsmfg.com
Thanks for the heads up, might split it into two sections. TOP (run) and BOP (branch) is only 11", really tight space.
FC
