ETABS Shell Stresses_ Difference between top/bottom/maximum stress
When looking at wall stress plots for direct stress do you guys look at top/bottom stresses or maximum stresses for reinforcement design? Can anyone shed any light on their differences?
RE: ETABS Shell Stresses_ Difference between top/bottom/maximum stress
Top/bottom stresses are due to out-of-plane moments. (Wall bending about weak axis)
Direct compression/tension stresses are due to in-plane effects. (wall bending about strong axis)
To design reo, you need to consider both simultaneously.
