Brace Connection Eccentricity
I have an HSS brace that's in compression. It is being connected at one end with 2 channels. The channels would be welded to the brace at the four corners of the HSS. Is there an eccentric moment in the channels/HSS from the compressive force? If so, is it M = C x e where 'e' is the distance from the centroid of the HSS to the centroid of the channel? See attached picture.
Thanks.
RE: Brace Connection Eccentricity
