Dab surface pump
Dab surface pump
Dab surface pump
Hello everyone,
I've just bought a second hand pump
It didn't come with power wiring cable. So having wired in cable and a plug the pcb started to smoke. I've looked at the components on the pcb,and it looks like it was the zettler az2100-1a-24de relay that has fried
As you may see,there's two terminals on the relay. Should I have connected them in some way?
thanks
Paul
RE: Dab surface pump
I googled dab pump wiring diagram euroinox 25/30 and there are lots of installation pages to choose from.
It appears to be quite involved,not just a case of sticking a couple of wires on.
In your diagram it looks a though its fried already so may not work.
Try google and see if its worth your time and effort proceeding any further.
Thanks theode. I took the pcb out and it definately is the relay that had burned out. Not fully sure if it was like that pre-purchase
You could try e bay for another pcb lol,or put it down to experience.
Check before switching on.
Smoke is a good indicator of something not quite right.
Yep,tried UK ebay,no joy. I should of inspected before switching it on,although the seller did say it was working.
