Surface wrapping of streamline body
I am new to surface modelling and have successfully 'wrapped' most of a streamline body using the 'Studio Surface' function.
I am however running into problems when trying to 'wrap' the nose section.
I am attaching the file and would appreciate any help.
I am not familiar with the different functions available so I would rather just ask here as I don't think it is a difficult problem to solve, but it will probably take me a long time to figure it out from scratch.
Here's looking at you, looking at me, looking at you
RE: Surface wrapping of streamline body
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is there a general rule for when the Through Curve Mesh or Studio Surface or other functions are better suited?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Lastly, if I want to now apply a thickness to the entire surface, what would be the best way to go about it?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
There is a "very simplified" explanation to that...
If you are a surfacing specialist, you will prefer the Studio Surface because it can deliver very clean surfaces if the curves are good.
If you aren't a surfacing specialist, you might prefer the Curve Mesh because it will always deliver, the result might not be that clean but it will create a surface no matter the quality of the curves.
And a more technical explanation,...
The studio Surface will attempt to create a surface where the internal math matches the math of the input curves, if the input curves ( the math) is simple, the the math of the surface will be simple.
The Curve Mesh will always create a degree3xdegree3 surface no matter of the math in the input curves. If and when the degree3 doesn't match the shape, NX will increase or decrease the number of patches in the surface.
Tomas
