Installing A Vertical Pump Horizontall, is it possible?
Hello everybody,
I have purchased a vertical pump but because of the limitation of the height of the room the pump can't be installed vertically. Could anyone tell me that i can install the pump horizontally?
Thank you for help.
Thank you for help.
RE: Installing A Vertical Pump Horizontall, is it possible?
Everything on the pump would be designed with the direction of gravity fixed, hence the top bearing would be designed for vertical weight and not really horizontal forces. similarly the bottom bearing could be quite flimsy as in vertical mode it only has to hold the rotor in a horizontal position with no weight forces acting on it.
The rotor shaft may not be strong enough in horizontal mode not to bend or flex and hence vibrate a lot. The frame and support for the motor and pump will just be all wrong.
Whatever you do the vendor will promptly void any warranties or repairs if they find out the pump is horizontal when you specificed vertical.
sorry - time to order a new pump IMHO.
Hydroturbines (pumps by night and electricity generating turbines by day)were laid angled up the sides of hills with no ill effects at all. I personally studied the effects of these with Herman Gruetink (an old vertical master) solely trying to find any deleterious effects from angle install. None were found.
Generally, I would say this is fine, but give us the details to tear apart.
length, stages, column length, shaft diameters, distance between lineshaft bearings, etc.
angle install is one thing, but completely horizontal is another.
Maybe yes maybe no - let's wait till we get more info.
