How can I verify that FEA analysis(like autodesk inventor and solidworks) match real world?
Hello All,
I am learning how to do FEA analysis on autodesk inventor (using you tube videos) and I see that blue, yellow, red lines on the body, when I apply a force on a body and constrain it. For example, I have a wooden table on inventor, I fixed the the four legs to the floor and now when I apply the force on the top center, I see where the stresses are high and where they are low.
I have two questions here,
1. how does the stress values help us? how can we use these stress concentration points in real life?
2. can I somehow prove that the stress analysis match the real life situation? any simple experiment? maybe I can break something cheap?
RE: How can I verify that FEA analysis(like autodesk inventor and solidworks) match real world?
2. Technically, FEA doesn't "match the real life situation." FEA is an abstraction, an approximation, of real life. It's close enough that we can live with that. Nevertheless, breaking something is a great experimental approach. Another possibility is to use polarized materials that can reveal their stresses through changes in their polarization.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
I am very new to this so I have more questions.
1. I can see that each color represent specific value of stress. Does the red color mean it will break at that point?
2. So next step would be to go to material properties, find the yeild strength, use some safety factor and compare the allowable stress to the stresses shown on the FEA model?
3. can you give an example of situation where FEA has helped you(or someone) significantly ? In other words, I want to know the real benefits of using it.
1) strain gages - if your predicted and actual strains match for the same loading you are on the right track
2) modal analysis - if the mode shapes are right and the natural frequencies are right
it's a bleeding miraclethe you have probably managed to get the masses and the stiffnesses right3) dynamic response - if you can apply realistic inputs dynamically to your model and get realistic vibrations (this is an extension of 2) then you are doing very well
4) fatigue life - well in theory you might be able to predict fatigue life for a complex structure. Good luck
5) static stiffness - not a bad check, at the very least you know your boundary conditions are right.
as regards 2)- in about half a day I could generate enough modal data to invalidate the FEA of a car body or powertrain.
Cheers
Greg Locock
Of course not, it is just a visualisation of how stress developes in the part.
Often the autogenerated "Von Mises" stress plot sets the red band to the highest stress level in your result (rather often a singularity caused by bad fixtures)
You can set the color band to what value you want and also note that there are other stress plots also.
If you're really confident that your setup and your assumptions are correct, and yeild strength is the allowable criteria, then yes. But based on your questions I feel that you need to know a lot more about FEA to be confident in your setup. Best way of getting the confidence is to perform a couple of hand calculations and then setup and compare results from FEA.
Strange question. You see it everywhere in your ordinary life. Engineers use FEA and hand calculations to decide how cars, buildings, aircrafts, consumer products e.tc. are designed.
I just assisted our design deparment, in a development project for an external customer, with FE Analysis. They worked with weight reduction, on a high stressed bracket and with my analysis we could remove even more material, compared to their original propsal, and in the same time reduce the stresses in the critical areas of the part with 40%.
how do we know FEA is a good tool to use ? 'cause we've understood the theory it's based on, and tested things enough to know (and to cautious) that we're (probably) ok.
how should you validate your model ? take some predictions from the model, test it and see.
I suggest that you ask your own senior engineers, since that would be for whom you would be doing the FEA. But, let's reverse the question; if you didn't have FEA, how would you determine whether your design meets requirements without building it only to find that it doesn't work, for whatever reason.
TTFN
Personally I've found it doesn't matter much which FEA package is being used, for linear FEA, the faults are almost invariably wetware issues.
Cheers
Greg Locock
