Unable to lanch pyuic from Qt Designer
When I am in Qt Designer, and do the following; Form > View Code, I get the error message: "unable to launch c:/python34/lib/site-packages/pyqt5.uic"
What to do? Does this also means that there is no way to translate from .xml to .py as well?
I am running version 5.4.1 of Qt Designer, included in Python34 folder, version 3.4.3
RE: Unable to lanch pyuic from Qt Designer
You might get lucky here, but the sister site Tek-tips.com has a Python forum: http://www.tek-tips.com/threadminder.cfm?pid=278
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
