Spring Qualification Procedure
Hello all,
I am currently creating a spring design qualification procedure for a fail-safe subsea valve. Current valve/actuator assembly to be qualified per 6A and 17D for which I have already created an extensive procedure for. My current issue is that our end user has specifically asked for spring qualification and the only requirements per API are in 17D-7.10.2.2.4, which is a 5,000 average cycle life requirement. Does anyone know of any other additional regulation or standard for fail safe compression spring design for the US?
Thanks in advance,
MGH
Thanks in advance,
MGH
