Issue with ray traced studio in NX 9 - "Black screen"
Hey,
At my current workplace, we recently installed NX9.0 on aproxiamtely 10 computers. They all run NX just fine, except when you try to use the "Ray Traced Studio". The pop-up window in which the studio is supposed to be is completely black, and causes the program to freeze (in return making the user force quit the application). Has anyone encountered an issue like this, or do you know how to fix it?
Thank you all for any help provided.
Best Wishes,
Sondre
Best Wishes,
Sondre
RE: Issue with ray traced studio in NX 9 - "Black screen"
I needed an adjustment in my lighting and it was good to go.
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
Obviously i will tinker a bit with the settings and see if it helps. Thank you!
Is this a certified Graphics adapter ( Read : Nvidia Quadro or AMD FirePro) ?
are you running the certified graphics driver ?
See https://support.industrysoftware.automation.siemen...
in the bottom of the page there is a horzontal line of links, "Certification" is to the far right
Tomas
Jerry J.
