export displacment for nodes in femap????
Hi, I try to export nodes after i defined them as group. I build a group of these nodes as picture below, and run analysis after choosing only this group to post out. My equation how could i see these nodes displacement after analysis??? and if i want to apply this displacement to only small rectangle alone without the big rectangle, is there a way for that???
RE: export displacment for nodes in femap????
first of all there isn't any picture in your message.
For the displacements question, if you have choose the option "Print Only" or "Print and PostProcess" in the Results Destination you should have your displacements in the .f06.
to import the results in Femap go to File / Import / Analysis Results then select your .op2 file from your Femap model directory and click OK.
List / Output / Results to Data Table. Select your Nodes and be sure that the data table is unlocked.
Hope this helps,
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac û France
