Design of Stiffened Rigid Column Base Plate Connections
Hi all,
I'm currently designing a fixed column base connection and have found a few guides which explain the design procedure for base plate size, bolt size and other requirements to resist both moment and axial force. However, all of the resources I've found assume no stiffening at the column base which results in quite a large base plate size. I was wondering how do stiffeners reduce the size of the base plate and if you know of any examples which I can follow that have a design guideline for this case. The column is quite small (150UB) and has small moment (4.75 kNm) and axial force (9.85kN) but, this results in a large eccentricity (M/N = 482mm) and if unstiffened, a base plate thickness of 35mm. I want to reduce this size and I think I have no choice but to use stiffeners.
Keith
Keith
RE: Design of Stiffened Rigid Column Base Plate Connections
ôIf you don't build your dream someone will hire you to help build theirs.ö
Tony A. Gaskins Jr.
