Replace component
Replace component
thread561-362010: Replace Component in Drafting NX9
Has the replace component for drafting views been resolved for NX 9 or NX 10?
NX 8.5.3.3
RE: Replace component
I'm fairly sure that there have been enhancement requests (ER's) to get the functionality back. You should contact GTAC and add your name to the ER. The more customers request it, the higher priority it will be given for future updates.
www.nxjournaling.com
While this may not be the outcome that people were looking for, it is a reasonable situation as the integrity of the original Assembly should be the responsibility of the designer and not the drafter, and while it might be true that in many organizations this could very well be the same person, it’s still only logical to confine operations which can affect the integrity, i.e. the design, of the Assembly to the module tasked with creating and editing Assemblies in the first place.
If you feel that having this function, being able to manipulate the content and structure of an Assembly while creating a Drawing of the Assembly, is critical to your workflow, then please contact GTAC and have them open an ER to that effect. That being said, I wouldn't hold my breath.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
1. add xyz.prt into the drawing.prt as a component
2. unpack assembly (if needed)
3. select this new component (not the drafting reference one)
4. do a replace component with 123.prt , check the replace all occurrences in assembly.
5. Delete the extra 123.prt file from the assembly (if needed).
6. Delete the obsolete xyz.prt file (in windows)
It appears that there is a functional need to replace a reference component within assembly or drafting. We do not typically document a part or assembly in a separate .prt file. But we have a case where we have a large assembly file that we are documenting it’s sub-assembly components, and after the drawing was completed the component names were changed, even though I was in the top of the assembly tree when I replaced the components in the sub-assembly the drafting reference component did not update. So the steps above was the only solution I could figure out to keep everything in the drawing linked up.
I'm glad the other thread had this option which worked! But for me it was after I have replaced them already...:
NX_ENABLE_REPLACE_FOR_DRAFTING_COMPONENTS=1
And John, I never hold my breathe when it comes to GTAC
NX 9.0.3.4
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
