Expanded Metal in SW
So I done a lot of searching found some GrabCAD models but they were all to small and unchangeable. Some people suggestioned a Texture and even a hatch, but when you need to see the parts behind the expanded metal, none of those options work. I tried the texture and in the model it worked OK... but in the drawing it was just a solid part without any representation and the items behind were no seen.
So I came up with this model that is a little large in file size 5MB. Also the expanded hole is larger than normal, but that is to help reduce file size. The part is a 48" x 120" Expanded Stainless Steel sheet that you can modify to your needs.
I thought I would share this with everyone since my site is no longer up and running.
Kind regards,
Scott Baugh, CSWP pc2
Gryphon Environmental
www.2gryphon.com
Quote:
"If it's not broke, Don't fix it!"
RE: Expanded Metal in SW
Thanks for sharing, Scott. I know what a PITA expanded metal, and other similar products, can be.
Jeff Mirisola, CSWE
My Blog
Thanks Scott.
You can also use the new fill pattern command.
Chris, CSWA
SolidWorks '15
SolidWorks Legion
ctopher,
I tried that but couldn't get the look I wanted plus it made it really slow. Using a sketch driven pattern actually made it perform better.
www.2gryphon.com
