how to connect cs flange to ss flange
Is it possible to connect a stainless steel flange to carbon steel flange
RE: how to connect cs flange to ss flange
Please note that the pressure-temperature rates of each flange are probably not the same.
Pressure-temperature rate of the entire flanged joint is of the lower (ASME B16.5: 2.3.2)
Go here:
http://www.farwestcorrosion.com/flange-insulating-...
Sometimes its possible to do all the right things and still get bad results
Everything else is speculation about the risk for galvanic corrosion, which probably is not an issue 95% of the time when this is done.
Conor Walshe
www.bellowsmfg.com
Bellows Manufacturing and Research, Inc.
https://bellowsmfg.com
Is it possible? : Yes
The issue over galvanic corrosion requires some water to be present to complete the circuit. If you have this inside or outside the flange then you need an insulating gasket or ring and bolt insulators.
