Change units
Change units
I have created a new component in mm.
I have a few dimension in sketch that have high value (110000mm, 95000 mm, etc).
How could I change the dimension in sketch (or part file) from mm to cm or meter?
MZ7DYJ
RE: Change units
Just try like 110m in the parameter field.
Mathi K
RE: Change units
MZ7DYJ
RE: Change units
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Change units
When I pick an expression the units area can not be selected anymore.......
MZ7DYJ
RE: Change units
MZ7DYJ
RE: Change units
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Change units
I'll try that.
MZ7DYJ
RE: Change units
Also, you can convert the units of an expression after the expression has been created, but that takes some NXOpen code to do it (it isn't an option through the GUI).
www.nxjournaling.com
