Abaqus Script - Create simple ODB without submitting a job
Hello.
I'm looking to create a simple ODB file using my model in session so that I can display an orientation tensor in a custom field. I'm able to create an ODB for a 2d part (made of s4 elements), but my system crashes whenever I load the ODB for my 3d part (made of c3d8 elements).
Here is my script. Any help would be greatly appreciated!
from abaqusConstants import *
from odbAccess import *
odb = Odb(name='4',
analysisTitle='derived data',
description='test problem',
path='4.odb')
sCat = odb.SectionCategory(name='solid',
description='Test')
part1 = odb.Part(name='part-1',embeddedSpace=THREE_D, type=DEFORMABLE_BODY)
nodeData = [(1, -5.0, -5.0, 10.0), (2, -5.0, 5.0, 10.0), (3, -5.0, -5.0, 0.0), (4, -5.0, 5.0, 0.0), (5, 5.0, -5.0, 10.0), (6, 5.0, 5.0, 10.0), (7, 5.0, -5.0, 0.0), (8, 5.0, 5.0, 0.0)]
part1.addNodes(nodeData=nodeData, nodeSetName='nset-1')
elementData = [(1, 4, 5, 7, 6, 0, 1, 3, 2)]
part1.addElements(elementData=elementData, type='C3D8',
elementSetName='eset-1', sectionCategory=sCat)
assembly = odb.rootAssembly
instance1 = assembly.Instance(name='part-1-1', object=part1)
# An element set on an instance
eLabels = [1]
elementSet = instance1.ElementSetFromElementLabels(
name='eall',elementLabels=eLabels)
# A node set on the rootAssembly
instance1.NodeSetFromNodeLabels('nall', (1,2,3,4,5,6,7,8))
step1 = odb.Step(name='step-1', description='', domain=TIME, timePeriod=1.0)
frame1 = step1.Frame(incrementNumber=1, frameValue=0.1, description='')
fieldout = frame1.FieldOutput(name="FO", description="Fiber Orientation Data", type=TENSOR_3D_FULL, isEngineeringTensor=TRUE, validInvariants=[MAX_PRINCIPAL,])
elist = [1]
strs = [[0.72539, 0.19255, 0.082066, -0.12808, -0.1158, 0.042058]]
fieldout.addData(position=CENTROID, instance=instance1, labels=elist, data=strs)
odb.save()
odb.close()
odb = Odb(name='4',
path='4.odb')
description='Test')
eLabels = [1]
elist = [1]
odb.save()
odb.close()
RE: Abaqus Script - Create simple ODB without submitting a job
