Popsicle Stick Bridge
Pretty good for popsicle sticks and some hot melt glue:
A confused student is a good student.
Nathaniel P. Wilkerson, PE
www.medeek.com
RE: Popsicle Stick Bridge
So, could a "deck" or glued on tension-resistant band be glued on to the bottom of the lower deck (under neath the bridge deck)?
I.E. you'd be given a certain amount of construction materials and told to build from that, or you were given a 'budget' of points and could buy materials. Left over points helped toward handicapping the results etc.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
which is how we used to quote the results of similar competitions at school (after loading it to failure, which you might not want to do ...).
Weight it can Hold: 64 lbs (weight of daughter)
www.medeek.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
and 1:256 is nice, no doubt it will get even better if you should test to failure.
Cheers
Greg Locock
www.medeek.com
David
Connect with me on LinkedIn. http://lnkd.in/fY7-QK
www.medeek.com
I managed to get hold of a two component room temperature polyurethane foam. So I made a cardboard mould, filled it with the rigid foam and, frankly, blew away the opposition.
They were NOT HAPPY accusing me of cheating and not playing fair etc. Teachers however were very pleased that someone had gone a different route than the triangulated drinking straw route that everyone else chose.
Happy days!
Sorry. Carry on.....
"I love deadlines. I love the whooshing noise they make as they go past." Douglas Adams
www.medeek.com
