NACE Vs ASTM Hardness values
Hello Everyone,
If a material(e.g.F22 after heat treatment)hardness falls within NACE requirements but outside ASTM requirements, what should govern accept/reject criteria?
RE: NACE Vs ASTM Hardness values
Pure logic:
If end user/project requires both: Reject
If ASTM only Reject
If NACE only OK
Note: Valid for any regulation or requirement: If something was OK before, but then is not OK anymore, then it is not OK until repaired or replaced smile!
Thank you for your reply.
