Piping with possible thermal expansion loop needed to pump suctions
Looking from a little advice from some piping engineers regarding a modification I would like to make to save labor and materials. During construction a feed line operating at 235degF and 30psig was designed with what appears to be a small expansion loop. I would like to remove the extra run and pipe straight to the center line of the split for the two pumps it supplies. I have included two ISOs and a 3d model I put together of how I would like the pipe to run. The material will be Hastelloy C276 Sch 40 8" pipe (SB-575 UNSN10276). My biggest concern is excessive strain on the pump suction inlets. I am not a piping engineer so I would love some advice!
RE: Piping with possible thermal expansion loop needed to pump suctions
These comments don't answer your question, but...
Perhaps the loop is there to avoid something/something that used to be there.
Are these all lap joint flanges? The symbology seems to indicate yes.
I hope those are not conical temporary strainers (witch's hats) downstream of the ball valves in FMP_3. If they *are*, check the length and which direction the cone is oriented and how you're going to remove it.
Should the eccentric reducer at the suction be bottom flat? Probably not.
Piping Design Central
Conor Walshe
www.bellowsmfg.com
Bellows Manufacturing and Research, Inc.
https://bellowsmfg.com
