Exterior Column Loads on Thickened Edge Slab Foundation
My company frequently designs structures with a thickened edge slab supporting the exterior walls of the structure. Recently I was asked to size this thickened edge for a structure that had posts spaced 8-ft on center. I have yet to find a reference for this type of situation. Typically, the load is assumed to be a line load from a wall not a point load from a column or post. There are some references that give guidance for interior columns on slabs; however, they all explicitly state the procedure is for interior columns only.
Anyone out there have some guidance for concentrated loads on a thickened edge slab foundation?
Thanks!
Thanks!
RE: Exterior Column Loads on Thickened Edge Slab Foundation
