UG Mass Moment of Inertia, Uniform Density
Good morning,
I stumbled upon the following thread:
thread561-330582: Mass moment of inertia
In which the OP is trying to determine the units of the moment of inertia calculation using -Analysis - measure bodies - show information window - method. A user responded to the question stating the MoI is returned on mass, not area and also mentioned that the material must be of uniform density.
Simply put, I am looking at a steel tube which is to be lifted with aluminum tubing. Is the MoI calculation invalidated because there is variable density in the assembly? Does the Analysis method assume a single density of the two options to act throughout the assembly?
Thanks you for your time,
Rico
Rico
RE: UG Mass Moment of Inertia, Uniform Density
