Coupled Temp-displacement Convergence problem
I m analyzing the rapid cooling (about 700C°C/s) of steel plate (thickness 1mm) in Abaqus/Standard.
I have same convergence problem like :
***ISOTROPIC HARDENING PLASTICITY DID NOT CONVERGE FOR ELEMENT PLATE-1
***THE SYSTEM MATRIX HAS 6 NEGATIVE EIGENVALUES
I tried
  • - reduce the size of mesh
  • - use automatic stabilization (damping factory)
  • - dashpots
but i can't have total convergence. What else can I try to eliminate convergences problems?
RE: Coupled Temp-displacement Convergence problem
Negative eigenvalues usually means it's not restrained properly. In addition, for rapid cooling use a very small time step and refine the mesh towards the surface where the temperature change is greatest.
