circularity / diameter tolerance
hello one more time,
well, haven't found exact answer anywhere yet so I am asking:
1) if there is a hole, with diameter let's say 50 and tolerance M6 and no form and position tolerance (circularity) is given on the drawing (and default workshop circularity is let's say 0.1mm) so then I can not exceed tolerance diameter range anyway, isn't true? otherwise it does not have sense in my opinion
in other words: DO I NEED to specify circularity for drawing with diameter 50M6?...
2) If statement above is true and circularity is specified, but with higer range, then M6 tolerance has priority anyway?
thanks in advance
thanks in advance
RE: circularity / diameter tolerance
I'd say it could depend on the situation, notably the part function.
50 mm M6 = -4/-20 um.
If this is a high performance connecting rod journal (not the bore) the recommended roundness and taper should be 0.0002" or 0.0001" (5 um or 3 um) measured as a diameter.
http://www.cleviteonengine.com/publications/CEB-1-...
