Pipe Reference
Pipe Reference
I am looking for some basic literature which covers pipe selection for water distribution systems. Ideally it would cover material, classes, ratings, cost; and other considerations relating to design.
Maybe someone could point me in the right direction, it would be greatly appreciated.
RE: Pipe Reference
I suggest that you would be better served searchibg the internet or even a search within this general engineering forum. The main reasons are that even if you are searching for general litterature, your particular needs could possibly not be covered within the text.
Fast moving development of practise, materials, general rules and regulations, local rules and climatic conditions, sizes and details, mains or local, adaption of pipes, buried, overground, cost/lifetime depending on selecting based on above variables, adaption and and anchoring aspects of pipeline, use of valves (air, vacuum, safety, relief, regulation, stop, pressure reduction, checkvalves and pumping equipment) and all variations to have influence of cost/lifetime is probalbly too extensive (even almost the sentence itself
I just tried the search water main pipe material as an example:
https://www.google.no/webhp?sourceid=chrome-instan...
Perhaps others can point to other general literature.
RE: Pipe Reference
Larry W. Mays- "Water Distribution Systems Handbook", McGraw-Hill:
Not sure of the latest addition for either of these.
RE: Pipe Reference
See the LANL piping guide in the link. It may get you started.
http://engstandards.lanl.gov/esm/pressure_safety/p...
Look under the fluid service categories such as domestic water and raw water.
RE: Pipe Reference
Like everything else in highly technical and complicated fields, there is probably no substitute for experience when it comes to good and dependable pipe selection. While many pipe salesfolk (reputable ones can provide estimating prices), trade associations and even government can provide helpful and educational guidance as to pipes and all sources should be consulted, one must consider carefully the source(s) and separate "the wheat from the chaff". Be particularly wary about "failure studies" or statistics that are funded/crafted? by special interests, or references that have very few authors or contributors -- consider the funding source, the quality and sources of the data it involves, and also exactly what and what not the chosen data includes - unfortunately just like much of politics and other stuff, one must follow the money. Remember though that it really makes little difference with regard e.g. to interruptions to public water supply, fire protection service, or traffic/trade whether a main is broken and must be taken out of service e.g. by someone digging into it (because they couldn't locate it properly, or it was just vulnerable to impact), ripping out a service line or a tapping accident, as opposed to a break caused by anything else.
While there is some hubbub of what is old and what is new or trendy, remember also all of the most commonly employed piping materials have really been around since about WWII or before, meaning virtually all of at least the larger utilities have at least some direct experience with all or most of them (unless the hands that had that experience have retired).
In summary, the quality of all references are not equal, and neither are all pipes. Finally, while the most expensive product isn't necessarily the best buy, keep in mind particularly what Wikipedia chronicles as the "common law of business balance" (at least some of which I think has been attributed by many to John Ruskin quite long ago), "There is hardly anything in the world that someone cannot make a little worse and sell a little cheaper, and the people who consider price alone are that person's lawful prey. It's unwise to pay too much, but it's worse to pay too little. When you pay too much, you lose a little money – that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot – it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better."
RE: Pipe Reference
